comstox
Thread starter- Joined
- Sep 29, 2017
- 186
OK guys, I need some brain power here from some of you smarty farty physics, engineer and propulsion specialists!
I had posted earlier about building a cool fast little river boat and was considering an inflatable, a small john, boat and the possibility of a long tail type of mud motor, but in the end I think a small boat with a 15?20 hp 2 stroke engine will meet my needs just fine.
But I have a prop height question:
How HIGH is TOO HIGH??? Keep in mind that, at times I will be in shallow water and don?t want my prop sticking way down under the boat. (Like in pic A.)
Looking at the blow pic I obviously feel that letter C. is TOO high simply because the prop is above the back of the boat, but is there some sort of scientific formula for the MAXIMUM HEIGHT? How will I know if it?s too high?
Can I lift the motor up (Even if I have to modify my transom,) so it is JUST even with the bottom? (Just a bit higher that the prop in digram B???)
Just a little background: I?m sure the engine will need to be a short height (short shaft,) of some sort. I?m shooting for a 10??12? boat.
I?ll shut-up and let you guys weigh in.
