- Joined
- Mar 8, 2009
- 44,792
This is just an assumption, but right now we don't have any other answer. The PWC is winterized by pumping 4 gallons of RV stuff thru the motor. Used RV stuff and not straight antifreeze (exhaust manifold) because of the inner cooler. The PWC didn't get used any last year and sat on an Easyport lift. This year close to the end of the season it was fired up and in short order it was over heating.
PWC is a Seadoo RXT 4-Tec which has been modified with a Riva performance system (larger injectors, inner cooler, sea strainer, supercharger, exhaust).
Started by pulling hoses off, and was able to blow thru the inner cooler (no clog). Removed the hose which connected the manifold to the stainless exhaust off. Could not blow any air thru the exhaust manifold using a blow gun and rag. Got some fittings to seal up tight and it took a bit more then 100 psi to blow thru it. There was a white color crystal which came out of the exhaust manifold. Only thing we could think of is this is RV stuff which turned to gel and crystalized. The inner cooler (SS) was good but the manifold (Aluminum) was not. Thinking that it was react with the manifold.
The Seadoo manual states to add 4 oz of full strength glycol antifreeze in the manifold. So the issue comes from using RV stuff.
Any others hear of this kind of thing?
