Tim Frank
- Joined
- Jul 29, 2008
- 5,351
Took apart lower unit to re-seal it. While I was in the process, I decided to repaint it.
I stripped and masked to do a better job and there is one part that I removed that I am unsure of how to replace.
The part is referred to as the water bypass cover. It is a rectangular plate ~ 1/8" thick, and about 3" x 1" , has two screws to attach it and has, for lack of a better description, a pattern of "cheese-grater-like" serrations. These would cut in one direction.
In this application they would act as either scoops, or vents.
The OEM manual is not detailed enough to show this, and the on-line parts diagram is unclear as well. It is a 50/50 shot, and it may not make a significant difference.
But, there was obviously a reason that the part was made like this and I have no idea what that is.
Is anyone 100% sure of the correct orientation?
Thanks.
Thanks.
