Terrellbarrell
Thread starter- Joined
- Nov 4, 2017
- 34
I am nowhere near ready for paint yet, but what would be a reliable brand of paint, how many coats, etc...?
It is a riveted construction. would you recommend tightening the rivets, or drilling them out and replacing them?Is it welded or riveted construction? If riveted I would do either a float test or fill with water to check for leaks after blasting. It will be much easier to repair any leaks before any paint work is done.
I agree, I personally know the previous owner so there shouldn't be any issues with it being stolen or anything, but I probably should get a title for it ASAP. I will check out Woodonglass's signature. Thanks for the tips!I would get your title issue straightened out first before jumping into the boat
re-buck the rivets - search the site, plenty of info
regarding paint, look for Woodonglass's signature. low $ paint on boats
Do you think aircraft stripper would work?Be cafeful sandblasting aluminum it will warp aluminum
Soda blasting may be a better idea
You dont really need to strip all the old paint off, sanding to prep it is fine, any bare spots you end up with should be treated with one of many methods including a self etching primer, or an epoxy primer, or alumiprep/alodyne to name a few. Then apply the paint system u choose.
Before I use the etching primer... what grain sandpaper would you recommend me to use to get the semi-deep scratches out of the paint and what grain should I end with before priming?
