FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Drain gear oil in a clean container so you can reuse if new,if old drain it,
You need to find a presure vacumm hand pumptool to test the lower unit gear box for leaks.
Harbor freight tools,amazon,e-bay, google search, buy one.
You tube videos explains it better than i can, it can leak out the drive shaft or prop shaft,
Is the drive gear the splines on the driveshaft/crankshaft? More than likely either the driveshaft seal(s) under the water pump or shift shaft seals are leaky. Pressure testing will help ID a leaking seal.
The oil is probably unburned gas/oil.
It leaks down through the cracks and crevices and settles in the low spots.
Change the oil and check for water?
Then do a pressure test if the oil is contaminated.
Some posters parrot their suggestions and really don't have a clue.
Makes sense. I could see it clear up to the bottom of the motor. I checked the oil level, it?s full, doesn?t look bad, but it?s probably best drain it and see.
