Isa4325
Thread starter- Joined
- Oct 7, 2017
- 121
OK I removed the flywheel and stator from the 3 cylinder 70 HP 707HE engine. OHM the stator to 1.0 to .9 ohms. Cleaned exposed shaft, key and slot, inside flywheel and magnets, stator ring which showed no continuity and charging wires(2) which did show continuity between the two wires. Needs a new distributor belt and will need timing. Then I will add the coil and condenser in replace of the old CD. YEAH!
