- Joined
- Mar 8, 2009
- 44,067
I noticed that the LU has a one full Drive-shaft, I would of thought they were a two sections :facepalm:
Both the 125 and the 105 have full length shaft
They started with the 2 piece drive shaft and it was a 1 piece gear case in 1989 or 1990 when it was the Force brand.
A Chrysler 3-4 cylinder gear case would not fit to a Force 3-4 cylinder engine from 1987 and up.
The 1 piece gear case came at the 3-4 cylinder engines during Chrysler brand in 1978-79 I believe.
Measured the shafts for the 105 and 125 and they are the same diameter. Would be easier to use the 105 leg then the other and is should work. Draw backs is finding a prop (as mentioned before) and if the 105 (really 90HP) gear case can handle the high HP?
interesting question and what about the gear-ratio?![]()
Your 125Hp power head will fit to the 105Hp leg and vice versa but the lower units will not fit to swap.
The 125Hp LU will not fit the 105Hp leg and vice versa.
