Monmouth00
- Joined
- Nov 26, 2017
- 198
In case anybody was wondering, here's what the battery switches, batteries, and rear bus bar ended up.
There's another bus bar under the console where most of the electronics are grounded. This is just a ground for the two batteries, sets of lights and the trolling motor outlet that life on the port side of the boat. It didn't make sense to run all that extra wire all the way around the boat. Saved some money and space for those thick battery cables.
It's not as "clean" as I had hoped, but it will do the job.
I got the wire into conduit and used cable clamps to hold it in place right at the base of the rear bench.I did the same with the power cables from the remote start. I stopped with the clamps just short of the "Y" where it splits for the battery/motor.
The battery cables are thick, and don't bend easily. This causes some problems getting the battery boxes to close. The starting battery box will not close all the way, no matter what I do. So, I'm content just cinching it in as is.
You can also get a view of the fuel/water separator. That's new, so I'll have to cut the old fuel line to accommodate.
