Monmouth00
Thread starter- Joined
- Nov 26, 2017
- 198
I agree there likely not much to be gained raising the motor.
But, how much have you played with the trim setting? Being you don't have power trim, what ever you set it at will be a compromise between getting it out of the water and cruising.
And a question, why is there a motor restriction on that lake? Who imposes it? Just curious. And why not just go to a different lake?
And a final comment, the older OMC 9.9 and 15's are the same, get a 15 and put a 9.9 cover on it, and watch your throttle position.
Dan
there are/were a lot of 30-35's running up North with 25 covers
Watermann & DLNorth - Your opinions are appreciated.
Yes, I've got a glorified trolling motor!
I will definitely play with trim. Right now it's on the second notch away from the stern. If there isn't too much of an improvement with the Doel Fin, I'll kick it out another notch and see if that makes a difference.
The HP restriction is set by the Division of Fish & Wildlife and NJDEP. Both lakes by me are wildlife conservation areas, I believe.
There are two main reservoirs near me - literally five miles in either direction - and both are awesome fisheries.
One is a state-designated trophy trout lake. We routinely pull 20" rainbows in. There are lake trout in the 180' lake (we don't fish them past 90') that exceed 30". State record that was taken there was 41.5" and 32 Lbs. The brown trout population is also growing - it had waned in previous years because a virus wiped out the stocking population.
The other lake has Whipers - hybrid white/striped bass. These are my favorite freshwater fish to catch. The lake also has big bass, Pike, and a healthy trout population.
Why would I go anywhere else when I can fish these lakes? ;-)
The motor I replaced was a 20 HP Mercury two stroke with a 9.8 sticker on the hood. IT moved us just fine. But when it bit the dust, I was looking to stay legal. There's a chance that I might swap the carb and the reeds to make it a 15 hp, but as I said, I'm not all about speed. I just want the boat and motor to be safe.
I'm heading out early on Wednesday with the boy. I'll report back if the Doel Fin makes a difference.
Thanks again!
