spacemonkey77
Thread starter- Joined
- Nov 16, 2015
- 62
Hey guys, thanks in advance for any help you can give me! I have a 1979 25 hp model 25904r evinrude, pull start.
This past summer it was running flawlessly. Now that it’s gotten colder (I use it for duck hunting) im having some issues. When I cold crank it it starts pretty easilly, but bumps and idles really rough and wants to die. When I put it in gear it just sounds funny, kind of like it’s bogging down. As I accelerate it kind of surges a bit and hesitates to take off. After a few moments it will kick in and run great at mid throttle or wot. Once warmed up it seems to run fine at higher speeds. When I drop back to idle it will run pretty good for a while, then after a while at idle it will start showing the same symptoms over again ( mostly bogging down). If I kill the motor and it cools off then the symptoms start over again.
I have tried richening the low speed idle and it seems to have no effect. I recently cleaned the carb and still no changes. It has fresh gas, fairly new fuel pump, new power pack and coil packs. Il
im at a loss! It ran rough last year when it was cold, then when summer came around I had zero issues. This winter however is far worse than last winter. Even letting it idle for a long time to warm up seems to not do much. Any ideas would be greatly appreciated!
