fmt2bx
Thread starter- Joined
- May 27, 2015
- 217
1990 130 HP 2 strokes Yamaha v4 ETXD
Symptoms:
When motor is running at or above 4000 RPM it doesn't maintain trim. Trim goes back to zero very slowly but surely.
What I can tell you for sure:
Tilt and trim sound normal , No grinding noises
In static mode, Tilt and Trim hold motor in what ever position I select for at least 8 hr.
No obvious leakage of fluid.
Reservoir is full.
I did use the manual relief valve 2 days ago just to make sure it was working properly as per owner's manual.
I did verify that the manual flat head relief valve screw was shut tight and it appears to be.(don't want to over tighten it either)
So the question is:
Could I have messed something up by using the manual valve?
Is it the typical symptoms of the system failing for a yamaha motor?
I only had experience with my old Mercury motor and when the trim was going bad it would go from working perfectly to not even holding motor in static mode for more than 2 seconds.
Thank you
Frederic 1 1 1
Symptoms:
Reservoir is full.
So the question is:
Thank you
Frederic 1 1 1
