Spark Plug Intensity.-
Sea Rider
If a Exciter Coil works with 0.2-0.3 Ohm resistance. What if having say 0.5-0.6 or slight way more Ohms, will this excess result in a poorer redish spark when measured with a spark tester and OB to run poorly at idle and not strong when opening up the throttle ?
Happy Boating
Sea Rider
What DVA does the exciter make?
Already got the digital multimeter, working on building the DVA adapter to check that out. Meantime will swap a new EC and check spark color. On my 18 horse when measured same, the spark is bright yelowish and strong...
Happy Boating
