starcraftkid
Thread starter- Joined
- Jul 5, 2010
- 238
Might anyone have any seat recommendations for a 16' boat for a guy who's 6' 7" tall and 360 lbs?
I've broken back to back seats, broken 4" aluminum pedestal bases and tops, had the inserts pull out of offshore pvc type seats, and had bench seats in my Starcraft Seafarer 16 rip loose of their mounting holes.
I built seat bases out of 2x4's and 3/4" plywood but at 360 lbs the swivels don't work, they flex and let the seat drag the surface below. I tried steel tubular seat posts, every one has broken off around where the tube goes into the bottom plate.
Any sort of plastic or aluminum based boat seat has failed. So have a few backed with 3/4" plywood.
The other day I was out in my buddies jet boat, we got a few good warm days and he wanted to put some time on his boat.
While running along at about 50 mph in open slightly choppy water the cast aluminum seat base and swivel exploded landing me on my back on the floor while at speed. The boat is almost new, so I'm sure its covered under warranty but
does anyone make a seat that can hold big man?
I tried the 'Big Man folding seats in my 16' open boat, they didn't last three trips before the bolts pulled out of the seat below or the backs broke off. On my Mirrocraft, its just aluminum bench seats, with wood backing them. I removed each bench and built up the wood panels with two layers of 3/4" plywood but it could only be single layer where it bolts up to the sides. Those sides have pulled away now. This time I've added four extra bottom braces, (legs), to the bench seats and welded up the ends of the benches with 1/4" aluminum reinforcements. Even with all of that, I through bolted a boat seat swivel, atop a 1/2" aluminum spacer between the swivel and the bench, and bought two "Big Man" folding boat seats. I used stainless 5/16" bolts, with home made 3", 1/4" thick stainless washers underneath, (installed before I refoamed the inside of each bench seat. The seats were attached with 1/4" stainless steel bolts into the factory anchors molded into the seats. The first thing I noticed was that the rear corners of the seat, the hinges, sagged down over the swivel and dragged the bench seat, even with the 1/2" spacer. I added a spacer to the top as well and the seats sagged even more.
I realize I'm a big man, but I'm not that big for my height. What do really big people do?
I had a pair of wood and aluminum offshore type seats in the boat for a while but they too broke. The flat 90° aluminum bracket that held on the seat back ripped out of the bottom of the seat on one, on the other, it just cracked.
Another problem with those seats were that they were extremely heavy, over 60lbs each. This is only a 16' boat.
Most of my fishing buddies are at least 300lbs, some lighter, some heavier so all seats need to take fully grown men.
Back to back seats I've seen have all been made from Plastic or plywood, so those are ruled out. What I've got now in the 16' Starcraft is two long boxes, each with a seat mounted at each end. Each seat is on a short pedestal. The boxes aren't going anywhere but I need a seat that won't crumble or collapse under me.
