Arestheblue
- Joined
- Mar 4, 2018
- 1
Ok, here goes. Yesterday I launched my boat and sucked up a bunch of mud to the point the tell-tale got clogged and there was no indication of cooling.
As soon as we got out of the mud, the general, non specific alarm went off, and I turned off the motor. Turned it back on, no alarm. So continued on my way. About 5 minutes later, alarm came on again, so rinse/repeat.
Eventually, the alarm came in and stayed in. Also, the motor would start vibrating excessively until I brought it down below 2000 rpm. I determined that we were unable to return too the original boat launch and ran it intermittently for the next few hours to get to another boat launch.
So far, I replaced the water pump impeller(looked pretty bad) and gave it a fresh water flush, but the only mud I got out was out of the tell-tale. Alarm comes in continuously when I have it turned over. I ordered a new thermostat, and I noticed an electrical connection near the front of the housing was disconnected, right as I was no longer able to work on it.
Also, it starts in gear now, but that was my fault when I replaced the impeller. I'm trying to figure out what could cause the alarm, I assume that is also what is forcing the motor into "safe mode."
