If this is in the wrong section sorry Mod.
I have a 16ft speedboat very similar to a 16ft Super Sidewinder.
Engine is a Johnson 140 with a 13 3/4 x 21 prop
Boat is 660lbs
Motor is 300lbs
Will have 2 5 gallon plastic tanks.
At present the tanks are in the back either side of the bilge.
Last season ran a Johnson 85. Had cav plate level with bottom of the boat. 3rd hole on the bracket.
Should the 140 be the same ?? or Higher Lower ???
Cheers Andy
Boat is 660lbs
Motor is 300lbs
Cheers Andy
