- Joined
- Mar 8, 2009
- 44,427
Will be installing a 40 PSI water pressure gauge on the block this season. Could use the typical 1/8 OD tubing but its typically -5 to 125 degrees F, for ice maker stuff, -5 to 175F for auto stuff, and -60 to 200F for shore D:70 stuff.
The shore D:70 is fairly stiff so this probably won't work. Could also use 3/32 ID or 1/4 ID to keep it from clogging but this could also cause a slow response on the gauge. The gauge being slow to respond would not be so much an issue, as would the stream of water coming in if it sprung a leak.
