1stgenbird
Thread starter- Joined
- Aug 5, 2009
- 397
I have a 1973 Silverline 19' in generally good condition. It has the 165 HP Mercruiser and what I believe is a MR1 outdrive. The last time I had it in the water was the summer of '16 when it developed a water leak around the outdrive. Circumstances last summer prevented me from even removing the shrinkwrap from winter storage so I did not use the boat at all.
This year I wanted to get the leak resolved so I took it to a local marina and after cursory inspection, I was told the transom is probably rotted and I should get rid of the boat.
As the boat was well cared for it's entire life, I find a rotted transom is hard to believe. I think the marina just didn't want to work on an old boat. In 2013, the same marina sealed the hull/outdrive withe silicone caulk and it had been dry for 4 years.
I will probably take care of the repair myself and the first thing I'm thinking of is to replace the gasket between the hull and outdrive and replace the two zincs that go through the hull. Does anyone know where I can get a gasket? I can't seem to find one for this year and model outdrive.
