1978 Starcraft 22 ft SS v5 restore
Status
Not open for further replies.
bob johnson
Yes Admiral! (Sorry, that's my over 22 year AF career coming out in me:)
The one in the middle is mine. I just saw the crack above that I need to fix. That must have been from the factory like that. I'll check that one tonight.
Rivets are going in good now that I got my process down. I was planning on getting them all done yesterday, but had some rain move in so I got held up for a few hours.
I'll have to do it today and tomorrow, then I should be able to leak test it.
Thanks for the encouragement and keeping me on track. I'm a new-by so I'll need a little coaching.
Ciao!
ha...its SIR....YES SIR!!!!!!!!!!! ha ha ha ha....keep at it!........i say even when bucking solid rivets..a coating of 5200 cant hurt! just wipe away all the extra....so it doesnt cause a large no stick area for the paint
mojoso72
Ah, great tip! I've been putting it on there, but not been wiping too clean. Thanks!
mojoso72
Did about 75 more rivets tonight. All was going well. I had both my sons in on it. A bit of a learning curve for my younger son. But, he did really well!
Tomorrow I'll pick up my new front cushions. I'm super excited about getting them back. The picture looks amazing.
See post above.
I have a lot of work ahead of me and I'm a little concerned about making my Scout trip with this boat. It's next weekend (1-3 Jun) :scared: Gonna keep pushing forward, yet I don't want to shortcut anything. If I have to I'll see about a rental for the trip...we'll see.
Once I'm in rebuild mode I should be able to crank it out. Might have to burn the midnight oil next week.
Wish me luck!
mojoso72
One of my nighttime jobs is rewiring this tangled mess. I have a new switch panel and fuse box to install to protect and neaten up the boat wiring. The main wire to the fuse block called for 2/0 AWG when I sized it up on www.newboatbuilders.com
The wire is going to travel about 30' round trip. It seems big, but with everything is running the fuse box could be up to 100 amps. Does that sound like too much of a draw?
I also need to recut and cover these seat backs with some additional material I'm picking up tomorrow.
Just a few more tasks to pass the time:)
Watermann
My 24v Terrova has a 50 amp breaker, what are you wiring up a garage or a boat? :lol:
Homes have 20 amp circuits. I ran fused 12 ga primary wire (20 amp) for power and ground to my fuse panel that runs all my accessories from a dedicated deep cycle battery. Nothing in my fuse block has over a 5 amp fuse.
baldwibr
The important thing is to make sure each power line is protected with the appropriate fuse within a foot of the power source- especially the wire that feeds the fuse panel from the battery.
If you need to, run separate wires with an inline fuse on your large amperage items directly from the battery (as opposed to through the fuse panel) so you don't have to spend big money on large awg wiring.
mojoso72
That is one of the charts I used too. I'm into overkill, so I went with the 3%:) Thanks for sharing that resource! Glad others have used this too. I'm sure I could have went with the 10% and been fine. Nothing too critical, except the bilge pump:)
Attached is the new panel I went with. Pre-wired and ready to install. This is gonna be a major upgrade as the boat only had 3 switches before. I loved the look of the toggle switched, but this was way easier to get and looks very professional.
Tonight, more rivets! Ciao
mojoso72
So I've had to slow down a bit. Not going to meet my deadline date, but that's ok. Scout plans changed and we didn't need a 3rd boat for the trip. Kind of glad, because now I can focus on getting all the rivets replaced that need it and take more time doing it.
I had to order some longer rivets for a few spots that go through 4 layers of aluminum so that was a show stopper for me. I didn't want to take any short cuts on structural areas. another 1/8 inch on a few rivets will make me feel better:)
Also, I have all the materials I need and I just need to finish sealing the rest of the wood. Once I get the rivets done this should go pretty fast. I hope:D Yet, in the back of my mind I know different. Something always pops up to slow ya down. Oh well, I'll deal with that as it comes.
mojoso72
On a positive note, I've been getting a lot of interest from my neighbors wondering how it's coming and saying they can't wait to see it when I get finished. That's a good thing, as I live in an area with an HOA and I've been doing everything I can to function within the guidelines of the HOA.
I'll get back at it this week and hope to finish the rivets by next weekend. Summer is coming and I can't wait tog et back on the water!
Thanks for all the help so far!
BWR1953
Hey, removing deadlines and slowing down can be a good thing. Removes a lot of pressure and stress. Sounds like you're making progress and that's always good!
mojoso72
Where are there 4 layers of AL?
Great question. Not sure of the proper terminology of the hull anatomy, but here goes. Pictures would help and I can get them tomorrow in the daylight.
There is a couple spots where an outside rib, hull, inside longitude and lateral ribs come together. That's 4 sheets of aluminum. It's only maybe a dozen places, but I want to make sure I get all the layers in the rivet.
A picture I'm sure would man-splain it better.
mojoso72
Not a great picture(It's an older one), but I'm headed out with the Scouts this weekend and wanted to show the area.
If you see where the rib line from front to back, left to right come together you can see 3 layers just on the inside because those ribs are on top of each-other. Then there is a rib on the outside making 4. Again, looking at it, there's only about 24 spots, but I'd rather do it right and not worry about it. In fact, the factory rivets was only through 3 layers in some of them. Me knowing about this would make me think about it at some point:eek: Probably not that big a deal, but...
I really like how y'all make me think about things and offer advice. Keep it coming!
Ciao
Watermann
The spray rail that is longer than most is riveted on the outside. I see.
fetch
mojoso72
Well, I'm back at it...FINALLY! Me and the boys have the time again to get back at this. We've had a lot going on in our lives, but now it's time to get it done. Looking forward to leaning on y'alls experience again:D
mojoso72
I need to replace the supports and face of the bow cover area. Had anyone done it with Aluminum instead of wood? Any pro's/con's?
Thanks for the help!
mojoso72
So the plan (right now) is to get it in the water this summer. The biggest obstacle I have is where I work on the boat. I don't have a garage big enough for the boat, and my driveway is slanted. So on the street it is. It works fine and I put out cones. Thankfully it's a pretty quiet neighborhood and the traffic is not bad.
Anyway, we're working on the rivets on the bottom. I need to get them done before I can move on. The trailer is in the way for getting to the back half of the boat and I was thinking about building some supports or just lifting up each side so I can access it to replace rivets. Any proven ideas on how to do this safely?
classiccat
Welcome back mojoso72 ! I can imagine that you're testing your HOA's patience at this point...or handed-out fishing trip vouchers to every single neighbor! :lol:
I personally haven't seen anyone use aluminum for bow supports. Some add a 3/4" PLY panel (to help reinforce bow-mount TM's). I doubled-up my bow planks by making a "T" for strength.
To work on the bottom rivets, have you considering removing the motor and flipping it?. It's great for not only rivet work but also sealing the double seam at the outer chine & prep/paint the bottom.
If you decide to elevate the boat off of the trailer, obviously exercise extreme caution; an empty V5 hull with a mounted V4 outboard is still probably pushing 3/4 ton.
mojoso72
@classiccat Thanks for the pic's. that looks good and I'll probably reinforce it too. Wood is probably what I'll go with since I was thinking of maybe mounting speakers up there too. We'll see...
As for flipping it, I just don't have the space to do that. When I paint it I'll have someone else do it. Painting is going to wait until the winter. Here is Texas it's plenty warm to paint. Plus at that point I'll pull the engine so I can replace the transom. Believe it or not, it's still solid! We never left it in the water and kept is covered all the time since my dad bought it new in 1978.
I'm thinking of just propping it up on the trailer one side at a time so I can get to it. Of course blocking it all along so it's safe...don't want to get crushed by that thing!
mojoso72
One step forward...4 steps back:grumpy:. The fun continues. The boys and I have been having fun doing rivets this morning. It's great to have 3 people doing it...1 blocker, 1 riveting, 1 sizing & putting on the 5200. Sure makes it easier!
Status
