WhyKnott
Thread starter- Joined
- Mar 9, 2018
- 29
Hello iBoats!
First post, be gentle!
Boater from Albany, NY here! Waiting for the SNOW to stop!
I am a new owner to a 2006 Bayliner 325 SB and twin 350 Merc MAG MPIs w/Bravo 3s. The Bravoitis bulletin was completed on it, not only were the hoses replaced, they also installed thru-hull raw water intakes (Although, without a strainer, a bit nervous about that).
On the sea trial, my surveyor with his infrared gun saw manifold temps get up to about 208 - Service has stated that this is considered normal operating but due to my concern, they pulled the risers and manifolds off to check the gaskets and for any obstructions only to find nothing. This is the side (starboard) that has new manifolds and risers. He also hooked it up to ECM diagnostics and was able to see proper flow numbers for the raw intake system.
Looking for ideas or am I worrying too much? Vessel is set to be delivered in a few weeks so I can get my hands on it if I need to check something.
