- Joined
- Mar 8, 2009
- 44,427
The Admirals Cadillac (110K miles) thru a P0442, which can be (from what I read) a vacuum leak in the tank, lines, purge valve, vent valve or canister. Jacked the car up and looked all over the place and could find nothing which stood out. First thing to check was the gas cap.
Web says the vent valve goes out more often then the purge valve, but one intermittent symptom leads me to the purge. Every now and then prior to the CEL, would come to a stop and for a few seconds the idle would be real rough. Then as soon as it came it would be gone and not do it again for a day to a month.
Found where I should pull the vales and connect a hand vacuum pump to see if they hold.
Anyone have any dealings with this kind of issue?
