toneybrown
Thread starter- Joined
- Jul 1, 2013
- 104
Ok, starting to get the feeling I was hoodwinked on this "Lake Ready" boat purchase.
So, I had another thread here about overheating issues. I figured impeller, so pulled the lower unit, replaced the impeller and buttoned everything back up. Put on the muffs, cranked water too it for a few minutes just to be safe and started her up. Temp gauge started low, then started creeping up. At 145 I killed it as it just never seemed to stabilize.
Now, to my observations. It does not seem as if the water is making it to the hoses that are connected to the thermostat at the front of the motor. The left side larger hose heated up, the smaller hose on the right stayed cool. T-stat issue possibly, no big deal I wouldn't think.
THE BIG DEAL!!
Under the carb, under what I think is the exhaust (Large iron bolted to block with a curved part attached to large rubber boot) water is coming out of the motor and running down the side!!! The water appears clear and is warm to the touch. It seems to be coming from possibly a gasket? A crack in something? It looks like it has been doing this in the past as there is rust on the lower part of the motor right under the exhaust...
There is no water in oil, still clean as a whistle from recent change. Oil that was pumped out was pretty clean, no water or discoloration. This gives me some hope. But I don't know.
What say you oh wise boat ones......Anyone tackle an issue like this before?
THE BIG DEAL!!
