I understand they will get hot, however these are hotter then I have noticed before, been boating for about 30 years.
Not sure what generation this is. The serial number of the motor is OW348398. I believe the it to be the standard cooling for this engine based onthe drawings I seen online. It is getting to hot for the touch, I have shot it with an IR temp gun but dont' recall the reading, it was last fall, the boat is not out of storage yet, in a bout a week or so.
Don't think it is bavoitis, the lower unit was off this fall to grease the spline and the mechanic doing the winterization did not say anything, and I think he would have knowing of this issue. If this were the case wouldn't the engine be overheating as well.
The recommendation I am getting from the mechanic is to replace the manifolds, but prior to going that direction I am wanting to assure this is the issue, both for cost and time reasons.
Once out of storage what are the checks to be done to help tell the root issue.
thanks for all the help.
