FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Quick one and something I haven’t seen info on before;
Is the RPM indicated by the smartcraft considered pin point accurate ? Presumably it is ? How is that info gathered by the ecu or ecm ?
Only as good as the sensor which is used to record it.
The RPM is 100% accurate so far as the motor is concerned, and should be accurate. The RPM tells the ECM when to turn on/off injectors and for how long, along with the other sensors which tells when to fire plugs and so on
Was thinking as much AD. Thanks for this. Amazing the variation between the anolouge tacho and the smart craft. Especially at the high end of the range.
