Cadillac-ack-ack
Thread starter- Joined
- Dec 1, 2017
- 104
Progress is progressing with this motor. A small set-back found me replacing a coil. Not because it was a cracked original, but because as I was installing new points I discovered the green point wire had been re crimped using a hardware store terminal and all but 2 strands were broken. Cutting the connector off and replacing it would have left the wire too short and I did not think I could successfully splice in a new section of wire. Setting points @ .020 got me pretty close and then fine tuning the adjustment using the flywheel and timing marks got me dead-nuts-on. Wrapping a rope once around emergency start groove in the flywheel gave me one nice white spark on one spark plug and one on the other. Before you say anything Racerone, I know about using a tester and I will once I have the starter motor on and the flywheel secure. This was a preliminary test.
Original spec plugs are J4J and replacements are J4C. Only difference I can see is the J4J has a cut back ground electrode. Can not the J4C be effectivly turned into J4J by simply cutting a hair off the ground electrode? Is it better? Maybe because the shape of the piston top effects mixture flow so a cut back electrode exposes the spark better? - Pete
