bhollehday
Thread starter- Joined
- Aug 16, 2017
- 77
I bought my first boat and wasn’t sure of the condition of the bearings so I pulled them. They looked good and had good grease. The bearing buddies kept the water out.
My question is how do I go about flushing the bearings without removing the hub? I’ve got disks with thread locked slide bolts and it can be a pain. Can I just use the axle zerk to flush until I see fresh grease or will I blow at the rear seal?
Also is the bearing buddies just used to keep positive pressure on the bearing to keep water out or also to keep bearings greased as it might lose some?
Also I read some recommend pulling bearings every season to clean, but with a system like this can I get away with flushing or longer intervals since grease is kept nicely?
