wmpotter399
- Joined
- Dec 15, 2016
- 7
I bought a boat a few years ago with a Mercury outboard. I finally finished everything in the boat. I am turning to maintenance now before the season starts. One thing that I noticed is that when running the engine at idle, there is no water from the tell tale hole. But it does start to flow as soon as you come off idle. I have been told that this is ok. But I do not know when the impeller was replaced last. So I was going to replace it. Thoughts????
Anyway.... After reading the manual and watching some people on You Tube, I decided to replace it. I Removed all the bolts and loosened the 2 nuts on the sides of the LU. I can only get the LU to move about 1/8" to 1/4". Some people are telling me that I have to disconnect the shift linkage up top under the carburetor. Some people are saying just those bolts on the lower unit and it pulls straight off. None of the marinas around here will touch it. They say it is too old. Can anyone point me in the right direction please?
