ford 302 cam shaft stuck, omc cobra 1989
Capt. Zack
I am going to use the cam out of the morotr that was in the boat. I am building another motor to put into the boat. The cam that is in the original block is difficult to get out of the engine it rotates but I cannot get it to slide out. I am having the same issue with the block I am building. The cam rotates but I am not able to slide it out. I have removed the timing gear and the plate under it.
Any pointers would be appreciated. I am sure that it is simple and I am having a case of stupid. Thanks
Jack
kenny nunez
Put the cam sprocket back on with the bolt to hold it. Put a flat pry bar under the sprocket and use the bolt to rotate the cam and it should work itself out. There is probably a ridge worn into the bottom of the cam bushings.
jbetzelb
Agree with Kenny. Please dont be pissed that I am asking this. You have the lifters out, right? I ask because I had this issue once and it was because I missed pulling one lifter.
Capt. Zack
I am not pissed, but all the lifters are sitting in the blocks. They are free and loose but not out of the holes
you could put a truck on it to pull that cam out, and until you pull the lifters, it wont come out.
engine rebuild 101
I personally would buy a new cam. if you do not buy a new cam, you must have the lifters on the exact same lobe of the cam or the cam will eat itself in the first hour of running.
Capt. Zack
I have the original lifters labeled with which hole they were located in. Thanks for the input.
GA_Boater
I hope you are keeping the donor cam and lifters together.
I very much doubt the cam bearings are ridged. The motor wouldn't run so good with a floppy cam because the valves can't open fully and lash can't be adjusted.
Capt. Zack
Taking the lifters out enabled me to pull the cams right out. I can purchase a new OEM cam and new lifters for 90.00 and I am thinking of doing it just to not have problems.
GA_Boater
Thought you said the lifters were out? As suggested in post #3 and afterwards.
Capt. Zack
The lifters were not out all the way. Seems as though enough to make contact. I was very gentle. I am a vintage motorcycle guy and these boats are foriegn to me. Be gentle and patient
