78hustlerpro
- Joined
- Jan 26, 2018
- 20
1994 Mercury Force 40hp isn’t pumping water out the upper spout. Motor fires up fine. I had lower unit off repairing the bearing cage. I think I got all the parts back in the right position, I didn’t have a problem getting the lower unit back on the motor. I looked at the impeller while the lower unit was off and it appeared to look fine. I’m not sure if I accidentally have something incorrect when I reinstalled the lower unit. Any guidance would help. All I know to do is drop the lower unit again and replace the impeller.
