NatedoggAZ
Thread starter- Joined
- Mar 7, 2018
- 182
OK - first time oil change - wanted to attempt myself instead of paying a few hundred for someone else to do it.
Would I do again - yes
1988 Mercruiser 4.3L 175HP Model 443S100AR 262 Cubic Disp.
I let the engine run for about 10-15 minutes and let the temp get up to 175 I believe on the gauge.
1. Took off the filler cap
2. Took out the dipstick
3. Attached the Quicksilver pump - shown below
4. Pumped until no more oil came out of the hose.. it took a while - maybe 15-20 minutes...it only came out a little at a time - I had a 10-quart flat oil drain pan I got from Walmart for about $9 which worked perfect
5. Put the dipstick back in to verify no oil on dipstick
6. Wrenched off the oil filter - now, this was not an easy task. I do not have a remote filter.. I basically removed this blindly. I had to reach WAY under the engine from the front. The filter was on the port side of the engine and underneath. I could not get to it from the side because of the seats there. If you have short arms - or thick arms, you are not going to be able to get to it. My arms happen to be just the right size, but i may have a little rash from the carpet. Without the oil cap wrench - there was no way it was coming of - it was on so tight, it was actually hard even using the wrench.
7. Added 3 1/2 quarts Quicksilver 25W-40 oil
8. Checked dipstick - it showed oil near the fill mark
9. Started engine - let run for about 3 minutes
10. Checked dipstick again - very little oil was registering
11. Added the rest of the 4-quart container - about 1/2 quart
12. Checked dipstick again - was close to the full mark
OH - when removing the oil filter - I got a big ziploc bag after I broke it loose. I grabbed the oil filter from the bottom of the bag and then twisted the filter the rest of the way off. A lot of oil still came out - not to mention all the oil still in the filter. It saved me from having to clean up a big mess!!!
I will check it again next weekend when I finish up my hydraulic overhaul - will probably need to add another 1/2 quart - because I believe the full capacity on that engine is 4 1/2 quarts...
Tools used:
Oil filter cap wrench type B to remove Quicksilver Oil filter
There was NO WAY I would have been able to remove the filter without this wrench.
Not a nice place to put the dipstick port - but I was able to get it to work without removing the mercathode. Had to bend the tube down a tiny bit in order to screw the pump on.
Pump used:
Quicksilver 802889Q 1 Oil Drain Pump
Took about 15-20 minutes to pump out the oil from the dipstick port.
Old Oil Filter - Mercruiser / Quicksilver: 35-883702Q
New Filter - WIX 51036
Difference - it is a little longer than the Mercruiser / Quicksilver filter by maybe an inch or 2.
-Nathan
Tools used:
Pump used:
-Nathan
