- Joined
- Mar 8, 2009
- 43,772
A few years ago, my 502 MPI, MEFI-1, VST, 415HP and went to a 509 MPI, MEFI-3, cool fuel, 530HP. Since then I've increased oil supply lines, oil cooler, installed oil temp and water pressure gauges. Motor oil pressure has increased along with flow (AN-6 to AN-10 lines), yet the oil temp has exceeded 220 degrees F.
This season I procured MEFI Burn SW and FAST Dual AFR meter and installed yet a larger 2 3/4 x 18 oil cooler. The exhaust tips are a bit black so this is an indication of t running rich. The excess fuel can and does increase heat in the oil/motor.
Took the boat out today and gave it run. Had the laptop displaying Scanner Pro and the AFR running, duct taper to the helm. Find out my AFR is staying close to 12 to 12.5 which is rich. Plan to change the tune and lean it out a bit, also get rid of code 44
