It used to be a way to see all my old posts. It is not here anymore, is it?
andreipou
I am not able to find this option anymore. Everything changed....
there was an update about 6 months ago and some of the old features are no longer there.
however if you click on your profile and go to activity, you can see many of the recent posts.
andreipou
Shows nothing except this last post.
It is a shame because I had really good trouble shooting advices there about my motor including the problem with shut - off switch that I got this morning. The post was only 2 seasons ago.
Really sad.
Tnstratofam
I miss this feature as well. Searching for a particular thread you posted in can be hard at times. At least for me.
GA_Boater
Yes, this works, but the filter range from the Filter drop down in the upper right hand corner needs to be changed to select a time frame. All shows 'em all if you have less than 200 posts. It takes more creativity for more than 200.
andreipou Give it a try. Tnstratofam Try the Advanced option at the bottom of the Filter selection drop down.
Moved this to Website Issues.
Click image for larger version  Name:	postfilter.PNG Views:	1 Size:	10.1 KB ID:	10571552
andreipou
Can you be more detailed, please?
How do I look for my old posts, let's say for last 3 years.
Thanks.
andreipou
I was able to find my posts from 2002 by motor model number, but can not find recent ones....
GA_Boater
Click your Username anywhere, then Activity tab, then the Filter. You will see a list of all 101 posts you've made.
Posts from 2002? You joined in 2008.
