ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
Hi guys, I have to replace th floor and transom on my 1976 starcraft.
I have some 3/4” exterior plywood (sheathing) Not PT either. I plan on sealing the exposed transom area with epoxy and varnish, and or paint. The flooring will be covered with either marine grade carpet or marine vinyl flooring, more than likely the latter.
My question is, is exterior sheathing too coarse for this? I don’t want to see rough grain showing through vinyl flooring etc.
also, what would you use to seal the wood? Epoxy? Spar varnish?
I know a lot of people use marine grade plywood, but if I understand correctly, Starcraft only used exterior grade plywood on these boats to begin with, and untreated that . I am replacing the wood for the first time in 42 years, so for my purposes I’m thinking marine plywood would be overkill,,,
