StingRay_90V4
Thread starter- Joined
- Aug 26, 2014
- 155
So i am part way through tearing the origanal floor out of our boat. The stringers and transom are in really good shape. So would the floor be except Sting ray thought the ski locker wiuld be a great idea and is is soft only around the cut out. So i am going to cover over it with the new floor. Is that okay to do ? Also , there is a large amount of foam. Or what looks like mono foam ( expanding foam. ) under the floor. But only on the outside ofnthe stringers closest to the side of the hull. Is that from the factory like that or is that from someone else after the fact. Because the foam is wet. It is holding a fair amount of water. I wont be surprised if i pull a hundred or more pounds of wet foam out if tye boat. Is the foam needed ? Do i have to refaom it under the floor or can i just leave it open and empty ? My boat is going to loose a lot of weight.
