Another fuel pump issue.
95 Lowbuck
Got a 1998 Trophy with the Merc. 4.3 carb engine.
Had not been started for awhile and tried to start it last week.
Not getting gas to the carb, and not getting any power to the pump or e-choke.
Splashed gas down the carb and it will run.
Bench tested the pump, works fine.
Followed the power wire that goes back to the starter, looks good.
Is there a oil pressure switch in this circuit?
I get 40 lbs on the gauge just off the starter btw.
Any ideas?
wellcraft-classic210
Is 12 volts present at the starter lug via a dc volt meter check ? If so it could be a fuse or connections
Any ideas?
The 40 psi is way to high for a carb
Check you kill switch
don't get any fuel pressure
My guess is you need a fuel pump but first;
Pull the filter and see if its full, if not go to the tank.
Remove the antisiphon valve and see if the ball and spring move easy
If filter is full then its the pump
bman440440
possibly the oil pressure switch P/N 805024 circled in red in the attached wiring diagram... also use it to check your wiring completely
Click image for larger version  Name:	fuel.jpg Views:	1 Size:	199.8 KB ID:	10579760
95 Lowbuck
I think my problem is electrical.
I don't get any power to the pump, bench tested the pump and it works.
You have an EFI motor and the oil pressure switch does not make a connection for power to the fuel pump. The switch sends a ground to the ECM telling it that there is a loss in oil pressure. The ECM supplies the ground to the fuel pump to turn it ON/OFF
Don't know if you have a MEFI 1 or 3 but here is the MEFI 1 with Alpha
95 Lowbuck
Thanks but I have a carb motor.
Dang, did it again :facepalm:
The oil pressure switch should be port side down next to oil filter or remote connection, or behind the distributor. It will have two wires going to it
bman was correct
Also, sitting probably has caused the carb float to stick. Sitting so long you may have to do a carb rebuild
95 Lowbuck
bman was correct
Thank you, I will check it.
I thought of this too.
Loosened fitting on the carb and still no gas or noise coming from the pump.
also check the anti-siphon valve at the tank. when you pulled the fuel filter and replaced it and checked the contents, what was in the filter
Maclin
The pump should get 12v while cranking. That may be hard to verify by yourself with a meter, but it should hum when the engine is getting cranked. That should be enough time to get some fuel into the carb. Many times the when the oil pressure switch is not working the symptom is the engine will start but not run very long.
Once you find the oil pressure switch, it has two terminals, and jumping across those should give it 12v any time the key is on.
Is this the first time you have tried to start it after a recent purchase?
95 Lowbuck
So it turned out to be the oil pressure switch, and fuel pump.
Hot wired the pressure switch and could hear the fuel pump,
but still no fuel pressure.
$400.00 later and the boat runs again!
Thanks for the update, hope you have an uneventful boating season
