ltcricket@yahoo.com
- Joined
- Sep 11, 2017
- 3
Ok I have done all I know to do so I am now coming to the experts. Bought 1985 ranger last summer with 1988 Mariner 150 on it. Didn’t get much time to run last year but did ok but was very hard to start. Like would turn and turn but not start and starter kept kicking out. So what I have done since then.
-Cleaned starter
-Changed bindex
-Changed starter
-put on 1000 cca battery
-replaced all the fuel lines including ones on motor
-replaced primer bulb
-replaced fuel filter
-checked choke (its good)
-replaced key switch
-cleaned carbs (they were very clean) none of the jets were clogged at all
-rebuilt fuel pump
issue now still semi hard to start on hose and harder to starter in water
-when I prime bulb it gets hard but fuel filter is only bout 2/3 full.
-When running there is almost no fuel in filter
wont run long before dying
-Was having to start at full throttle but when I backed off to put in gear would die
-after it starts runs and dies the primer bulb is soft again.
So there you go any help would be great. If I left off anything just give me a shout
-Cleaned starter
-Changed bindex
-Changed starter
-rebuilt fuel pump
