lmbr
Thread starter- Joined
- Jun 24, 2012
- 69
84 Johnson 60 hp restoring. Compression on both cylinders is 115 - 120. After overhauling carbs and completely cleaning fuel system engine started right up. But when I started the motor, there was no Tell Tale so I overhauled the water pump and replaced the impeller. I am using earmuffs. When I had the lower unit off, using a water hose and nozzle, I ran water thru the Tell Tail hose and water came out of the tube the water pump connects to. I know running the water thru that hose is the opposite direction of normal operation but I was trying to see if the cooling system was blocked. When I originally got this motor and used earmuffs the tell tale worked. 2 questions: Is there a way to run water thru the system to flush it without having to pull the lower unit again. And do I just need to put it into the lake to try it. (Closest lake is 30 miles away I also could put the motor in a horse water trough if that would. I do know not to put the prop in gear when doing this.)
