Stupid Question But I'm Going To Ask it Anyway...
Quarterwave
Hi everyone,
Can I remove a couple of intake manifold bolts to install some lift-point brackets and a bracket for some relays/wiring, without needing to use new gaskets and china wall?
The engine has NOT been started since I replaced them all.
Thanks!
AShipShow
Don't see any issues as long as you didn't lift up on the manifold at all...
TurtleTamer
I would clean the threads up and reseal if applicable but you should be fine.
assuming V-motor.
I myself suggest the accessories holes in the ends of the heads vs the manifold bolts for lifting. however only pull two at a time, pull fasteners, clean , then re-seal the threads
achris
More fish than mountain goat
assuming V-motor.
I myself suggest the accessories holes in the ends of the heads vs the manifold bolts for lifting. ...
Can't say I disagree, but Merc install the lift eyes on the intake manifold bolts... Never seen a problem with them...
Chris........
Chris........
merc also designed the 470 and vaser.......
a 3/8" bolt in sheer is 10x stronger than two 5/16 (M8) bolts in tension, especially if you know anything about rigging and sling angle deductions
Quarterwave
Thanks everyone, much appreciated!
Yes, Scott - 5.7l Mercruiser.
