samocamo123
- Joined
- May 23, 2017
- 33
Hi, I have an Ebbtide Montego 170 with a 3L OMC Stringer 400 (302STHRCOM) and I noticed in WOT I only reach 3000 RPM, it can't be my prop as its a 13 3/8 x 17 pitch and is what I believe to be the factory prop (its a little dinged up but not enough to make a noticeable difference). It also couldn't be gearing or outdrive as they are stock. I set my timing with a timing light to about 4 degrees BTDC and it didn't help much with RPM. Although I am not entirely sure if my timing was set correctly as I just set it while idling in neutral as I couldn't find any instructions. It idles in neutral at a little above 1000 RPM. It runs a tiny bit rough (still runs fine most of the time) idling in gear, but with any throttle applied it smooths out. The engine reaches 3000 RPM at about 3/4 throttle but seems to increase in power going to WOT but doesn't increase RPM. The engine isn't overheating either as it runs about 150-160 idling and about 170-180 at WOT. What could be causing my low WOT RPM?
