glennj3
Thread starter- Joined
- Sep 6, 2011
- 381
Very odd thing, for the first time in years my boat is fixed and running great. Went out 2 times ago, hit a log, very hard but driving relatively slow. Struck several times before I could get out of this shallow area.
While driving to a sandbar where other boaters were hanging out I noticed my oil pressure was at like near 0 ! Engine sounded like normal. After turning engine off, later when ready to leave I noticed the ignition switch did not turn on anything under the dash (lights, instruments, fuel gauge etc.) the engine would do nothing. After getting home the first thing I did was look under the dash, found a large red wire with an in line fuse, it was burned. Replaced it and everything fixed!
So I went out again last week, no problems except after running a while I saw at idle the engine oil pressure was again near 0. I have a second gauge direct to the engine, it was showing the same pressure like about 5 lbs. Again the engine sounded normal. Oil pressure goes up at higher RPM but not at 40 like it used to be.
It seems to be taking on some water in the engine compartment also with oil leaking and floating on top of that water. Not a lot but enough.
The outdrive looks good, the prop does not look like it hit anything.
Sure would like to know what to look for?
Thanks for any assistance.
