dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I noticed that the valve cover gasket on 1994 Mercruiser 3.0LX was leaking oil and I bought a replacement rubber gasket on ebay. Put it on the valve cover, used gasket adhesive, tightened up the cover up to spec torque. Took the boat to the lake today and noticed another valve cover leak, similar to the old one but in different location. Tightened up the cover a bit more, leak did not disappear, remained the same or just a little smaller. Did not want to break the bolts, so I took the boat home took of the valve cover and found out the new gasket is in even worse condition than the old one, also split in half where the block was pushing on it, almost chewed up in the other places. It could be because I tried to tighten up the valve cover on the lake, but does not explain an original leak. The gasket is Mercury-Mercruiser Valve cover Gasket 27-806452 it is rubber gasket not cork one. It could have been old and deteriorated a bit, the glue on the bottom was kind of dry and did not stick, but it was in a new sealed bag and ebay seller said it was not this old. Im going to buy a new gasket in the marine store, but it might take a while since they dont have it in stock. The question is, should I buy a rubber or cork gasket (seems like cork would be a better choice, considering the outcomes with two rubber gaskets, original and replacement one. And second question is can I buy an automotive valve cover gasket at the autostore. This will be much faster and I can finish it tonight. And if they are similar, is Mercruiser 3.0 4 cyl engine also using Chevy block, or it is different?
Thank you
Will post the photos of the gaskets in next post.
Thank you
