Kedwards68
Thread starter- Joined
- Jun 17, 2018
- 10
I recently purchased a 1996 Regal Commodore 292. It has dual carbureted Merc 5.7L with Alpha drives...gen 2 I believe. On the hose with water to stern and fresh water intake both motors start and idle well. I never have run the motors above 3000 rpm and above idle only for a second or two. The boat is new to me and I have let it idle for a while while checking out other systems. After a while I have had the motors get hot enough to set off the alarm. They were shut down immediately. I had a smaller Regal that would get warm on the hose on a long saltwater flush so I didn't think about it too much. I finally put it in the water and both motors got hot about the time the boat got on plane. I shut it down and was lucky enough to coast back to the dock. I'm thinking the hose pressure might have made up for impeller insufficiency. Sea-cocks were open.An impeller issue is the first thing I will check. I'm trying to find info on the removal of the freshwater pumps. The stern drive impellers I am familiar with. It looks like I can remove the whole bracket with the pump attached to it. Is this the best way to get it out? I've watched videos on it but the motor is out of the boat. I need any advice I can get on replacing the fresh water impellers with motors in boat. Also on anything I could be missing.
