Need help troubleshooting high idle problem.
wellcraft-classic210
Their is a link to online manuals in the stickies ( at the top of the forum --- should have what you need and its a good link to keep.
Eastboundndown
Thank you. And thanks for the help. Do you know if or what the difference is between large box modules & much smaller distributor module for TB IVs.. I just found out there are different ones and different sensors in dizzy.. the one I have in my dizzy now is magnetic with the 3 lead wires built in. The other type is electronic I think and has the two studs to attach wires... just want to make sure I didn’t install components from different systems. And my last question on ignition system is this. Do the modules need to be programmed or tuned somehow or No? Thanks
