JJBoatr
Thread starter- Joined
- May 3, 2011
- 144
Morning Y’all,
My brother recently acquired a nice Four Winns 170 Freedom with an OMC 2.3Lthat had a roached upper gear set. He replaced the entire lower unit with a small case driv from a boat equipped with a 3.0L. His boat is running great except for one thing...he cannot reach recommended WOT (5200 - 5600) with a 13.25 x 17P propeller, best we got was 4500 at 37mph and that was trimmed to the ragged edge of venting. We were both told by a local mechanic that the 2.3L & 3.0L shared the same identical drive ratio.
What I think I’ve discovered is that the two engines did not share drive ratios except for a couple years in the mid 80’s. According to an old post by the greatly missed Don S., the 2.3L had a drive ratio of 2.0 and the 3.0L had a ratio of 1.71. I also have other evidence in my 1992 OMC factory brochure showing a ratio of 1.84 for the 3.0L engine.
Now, OEM parts fiche shows the same upper gear set is used for both engines, however the lower gear set part numbers are different and this makes sense to me because the lower pinion is where the final ratio reduction takes place too my knowledge.
So the big questions...can anyone confirm the ratios were in fact different? If they are different: are we fighting a losing battle by trying to overcome the ratio with a prop change? I think we might be. We want to try a 13.5x15 but we will at best gain 400 rpm which still puts us below the lowest recommended WOT of 5200.
Background on what we have done to the boat to rule out other problems that would cause the seemingly low power.
Verified anti-siphon valve was good, verified unobstructed fuel pickup, set the points, verified advance, rebuilt and tuned carb (Holley), verified no exhaust obstruction with bore scope. We even gave the carb an extra shot of fuel carefully with a windex bottle while at top speed, engine bogged a little and didn’t pick up rpm, fuel supply is good.
We really appreciate any experience based assistance anyone may provide. If anyone has this engine in a similar sized boat it would be really awesome if you could share your top speed and other performance characteristics.
link to the thread Don S. Posted in
https://forums.iboats.com/forum/eng...nes-outdrives/463666-3-0l-cobra-vs-2-3l-cobra
