Hello all,
My boat has a omc 140hp engine paired with a 120 sterndrive.
I got the boat on the water and it seems the boat does not want to get on a plane so when i throttle it kind of just revs the engine a bunch but I dont get anymore speed out of it... I was told its possible my prop might be spun or my outdrive is not deep enough? I look to see if i can lower my engine a bit to get the outdrive lower but I could maybe adjust how its sitting to maybe get it lowered by an inch.
Next time i am out on the water I will update with photos of the back of the boat in water.
So before i was told that I bought some self adjusting trim tabs for the back of the boat and installed them, they definitely helped with stability and such but still not getting on a plane.
I took the propeller off today. And it seems there is no spindle nut on there so it cant really be spun right? The shaft does not seem to have any play. The shaft spins because of the breakaway pin, but looking in the manual it seems the backend is missing a thrust washer there was not one to be found. So i ordered one and will put it on shortly.
Now my question is, can a missing thrust washer cause my boat not to get on plane and accelerate properly?
thanks,
Andy
thanks,
Andy
