AlabamaNewbie
- Joined
- Jun 25, 2018
- 239
Yeah screws or rivets are all good. No issues.
Make sure and Powder your TOTAL self with baby powder from now on!!!
I think that might make the neighbors talk a bit too much.....
300 seems high to me if you're removing all that... with that said I have no basis for that guess lol.
Cons; It will not be cheaper.
Because this thing has 4 stringers 1" thick instead of 2 @ 1.5", the cost to do wood/fiberglass doubles. The amount of material needed to glass in a stringer is mostly the same between them (difference being the 1/2 inch over the top). So compared to SeaCast, its not cheaper, but it's pretty much the same. After taking accurate measurements last night and calculating on their website, I will need 14.4 gallons of Seacast, but I intend to get 20 gallons for safe measure. Of course I am quite a ways out from that, but I try to plan way ahead.
I am interested in your hindsight revelation though, as I have a few spots in the bow area where the factory didn't even try to get it glassed. I guess they figured if water gets up there, you're done anyway. lol
All told, you're IN DEEP, friend! I'm always picking up Resin. One thing I will say; In a pinch, you can buy the 1 gallon Bondo Fiberglass resin at WalMart for $35. After having bought online through several different disty's, I can It works just fine. I've had no problems with it. It's compatible with pretty much everything from everywhere else I buy (Fiberglast, West Systems, 3M, etc).
