skyman2112
Thread starter- Joined
- Aug 7, 2015
- 80
Hi group, how can i increase the water pressure especially at idle? Bought this boat new in 2011 and after the first few years its been hard to keep the alarm from going off and even went into gaurdian mode a few times a year. I been to the dealer and they ran it with a clear hose attached and it didnt show any signs of air. Replaced the pump housing and impeller several times and the water pressure sensor 3 times but still it barely has enough pressure to keep the alarm off. I finally bought my own scan tool so i could monitor it while driving.
The water pressure varies from 0.7 to 3 psi at idle. If i give it some gas when i start it then go back to idle, the pressure seems to stay higher. And at cruise i have. about 10-12psi at 3300rpm. Alarm goes off mostly when its warmed up. and less often when I first start it cold, i/e the thermostat is closed, So I changed the poppet valve spring thinking maybe that was stuck open but the old spring was fine.Water temp is always good, lots of volume too. any ideas no matter how crazy would be appreciated. Can i adjust the pressure sensor to read higher somehow? Install a resistor? Anything to keep the computer happy on my otherwise perfectly running 377Mag with catalyst exhaust. S/N 1A645849
