Leardriver
Thread starter- Joined
- Oct 7, 2008
- 382
I got the alarm yesterday while underway, quickly ruled out low sea water psi and engine overheat, and found the gear lube reservoir low, so the alarm did its job. The reservoir was full when I started. I have never used a drop on this 107 hour boat, and the reservoir was empty.
So, put it on the trailer, saw a leaking stream of lube up high on the outside near the shift cable. Looking at the parts fiche, there are a couple of fittings that it could be, some easier to access than the others.
Hit the messy spot with a quick blast of carb cleaner and pressure washer to clean and help identify the leak source, refilled the reservoir inside the engine compartment.
Came out this am expecting to see a drip stream, but nothing apparent. I guess the outdrive is slightly pressurized while underway, and the leak is tiny, so not enough pressure to make the leak show itself when it's not running.
So, my question is.....can I insert a low pressure air compressor blower nozzle into the gear lube reservoir to help force the issue and make the leak show itself? Maybe 8 psi regulated at the nozzle?
2004 Sea Ray 270 Sundeck 8.1 OM672099, drive B3 OM701661
