mbhoag
Thread starter- Joined
- Aug 29, 2011
- 147
OK, I am pulling what is left of my hair out!.
Here is the short version: Tachometer is not working.
2002 115 EFI 4-Stroke Model 115ELPT4S Serial OT540017
With Ignition on (but not started), tach can read slightly above zero, once started, it goes completely to zero.
What I have done to track it down to try and fix...
I am guessing because this is a 4stroke, the system is slighly different than those on 2 strokes, which is why this system seems to be wired different. It has one grey wire, that feeds from the engine into a "Tachometer Signal Converter", which outputs the 3 tach leads (grd, power, signal). Not sure how you get 3 from 1... but they do.
Here are my guesses..
Are there any diagnostic procedures I can use out there specific to this engine?
I appreciate help, this is MADDENING!
Mark
- Replaced original Faria Tach with a brand new one (set at 6 poles)
- With Ignition on (not started) voltage between black/purple at tach is 12+v (DC)
- Start Engine, voltage between black/grey wire at tach is virtually Zero (A/C)
- With Ohm meter, checked continuity of grey wire from tach back to connection at motor (it is fine)
- Verified with meter that Battery IS being charged by system when running
- Replaced Regulator unit with new one
- Replaced Tachometer Signal Converter
- Since batteries are confirmed to be charging while the engine is running, the stator is fine.
- Since Tach, Regulator and Tach Signal converter have all been replaced, they are also fine.
- So I am left with the single grey wire feeding the Tach Converter, how can I test that wire?
Mark
