Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
I'm restoring a 2 strokes powerhead to immaculate clean factory condition, that's removing all carbon deposits on combustion chamber and exhaust cover area as well. Been using CRC Tune Up carbon remover frequently so carbon build ups were not found that wow quantity.
Been spraying carb cleaner spray on carboned parts and removing them mechanically with different scrapping tools with excellent cleaning results, was wondering if any carb spray sprayed through carb with engine running say at fast idle speed at neutral or geared forward with achieve same cleaning effects as a true carbon remover product. BTW both are highly flammable products. To lower costs the carb spray costs much less than the tune up one and easier to get.
As my head gasket has low used hours and came out in excellent condition plan to clean it as when new, the issue is that will lack the glue coatings on both sides. Don't want to use any gasket dressing, silicone type, whatever. Was wondering if spraying several coats of woman hair lacquer or several layers of automobile lacquer with a brush and letting them dry one on top of the other will do the trick ?
All mating surfaces has been conveniently polished to fingertip smooth perfection. Head and exhaust gaskets will be torqued back to factory specs with a torque wrench. So lacquer coats should seal well mating surfaces when OB starts to warm up, right ?
No,my lady won't have any issues lending me her hair lacquer spray for that purpose LOL!!
Happy Boating
Happy Boating
