WilWait
- Joined
- Jul 2, 2018
- 16
[h=2]I have just acquired a second hand Johnson 9.9 and have a similar problem to the one OptsyEagle described at legnth in 2014.[/h] https://forums.iboats.com/forum/eng...boards/655499-9-9-johnson-may-have-overheated
Sadly for me the thread seems to have gotten off track and was closed before the real cause of the leak was identified. No correct fix was suggested or tried. Did the thread continue on another topic or has this issue been resolved elsewhere? If so, would you be kind enough to share the link? Thanks.
I did my spring maintenance and changed the oil in the lower unit. I filled it in the upright position and did not overfill.
I took the 9.9 on it's maiden run last week and after a few burps, she ran smoothly under full throttle. No issues were noticed till the next day when I saw oil leaking from the water out ports.
I cleaned it up. I took pictures every 24 hours and the leakage seems to diminish, although not anywhere near what I would consider normal.
1) What is the source of this leakage please? (Maybe OptsyEagle can fill me in...)
2) How do I resolve this issue?
3) OptsyEagle are you still running the same outboard? How is that working for you?
I am a new member and new to Johnson outboards, so thank you for your patience with me.
Will
Will
